Fuel Door Release
Don't have a problem with it, yet, but I'm concerned for the potential of it happening. Is there a manual release for the fuel door on the 2005 V70? I've looked behind the access hatch for rear bulb changing and didn't see anything obvious, at least without using an inspection mirror. I'd hate to learn it didn't work when the tank was really low, and, of course, that's exactly when it would happen. Thanks for your expert assistance.
Geoff
Geoff
Found out last night that it is possible to manually release the fuel door. Just feel around behind the foam covering the mechanism until you locate the cylindrical plunger/latch on the left side of the door. I was able to gently retract it toward the back of the car. It moved easily with very little resistance. Didn't need to remove anything, just open the bulb changing hatch. I assume it will relock when my wife drives off this morning.
Geoff
Geoff
You have a point there Geoff!
R.
ORIGINAL: GeoffC
Couldn't find a word about what to do in case of electrical failure in the manual. I suppose this is not really much of a problem. I just figured there had to be a simple way to do it. Maybe Volvo figures only soccer moms will be driving this model.
Geoff
Geoff
