Fuel door release
Old Nov 19, 2010 | 11:59 AM
ibified's Avatar
Default Fuel door release
I went to put gas in the car today (94 wagon) and couldnt get the gas door open. it appears that theres a latch that catches the fuel door that you need to pull from inside. the problem is, i dont think i HAVE a fuel door pull inside the car.
Any ideas?
Old Nov 19, 2010 | 01:29 PM
MC92's Avatar
Take the cover off the right taillight from inside, same process when changing the light bulb. There should be a handle/hook you can pull. Motor might be out that unlocks it.
Old Nov 19, 2010 | 01:47 PM
ibified's Avatar
but why would it be locked? It's never locked before. How do you unlock it? I was able to get it open, but i need to know what you are supposed to do in order to get it to release.
Old Nov 19, 2010 | 02:39 PM
trektech's Avatar
Your fuel filler door is supposed to lock every time you lock your car doors, and unlock again
when you unlock your doors.
Old Nov 20, 2010 | 11:18 AM
boxpin's Avatar
Its part of your central locking system. If it is not unlocking with the rest of the door locks then you either have a faulty actuator or its getting hung up on the door tab.
Stand at the gas door with the gas door open then lock and unlock your car. You should see the pin come in from the rear of the opening.
Old Nov 22, 2010 | 06:36 PM
ibified's Avatar
yep. that was it. thanks all!
qcvol
Jun 17, 2013 09:55 PM
alexwangtx
Dec 17, 2011 08:39 AM
duckdodgers
Oct 17, 2011 01:39 PM
fernandos1
May 24, 2008 03:21 PM
GeoffC
Feb 4, 2006 12:52 PM
