Fuel Problems
Old Aug 2, 2006 | 03:25 AM
mo t5's Avatar
Default Fuel Problems
OK The wifes car went to the shop for tires so I thought I'd drive the V70 for a couple days. Changed the oil, the car cranked for a while then started. I waited about an hour and checked resting fuel pressure, got just a small spurt. I then turned the ignition on without starting the car, no pressure at all. Then I went to the rear and banged on the floor, still no pressure. I then tried to crank it and after 15-20 seconds it started right up and had no driveability issues. Is it safe to ASSUME that since it has little resting pressure its probably the check valve that is bad with maybe a cranky pump, or maybe the relay? Its been acting like this for a while. Thanks.
Old Aug 2, 2006 | 10:04 PM
Default RE: Fuel Problems
The Check Valve inside the Pump.
The assembly is like $300.00 or so.
Old Aug 2, 2006 | 11:10 PM
mo t5's Avatar
I knew it. I just wanted to hear you say it before I whipped out Mr. MC. Thanks Tech.
Old Aug 7, 2006 | 02:05 AM
mo t5's Avatar
Does the pump get voltage when the ignition is on? I checked it today and it got no voltage with the switch on, 10.91 when I activated the starter. I'm just trying to make sure its the pump and not the relay.
Old Aug 8, 2006 | 01:17 AM
The pump will get Voltage for a second oe 2 when you turn it on then when you crank it you will get voltage again.
It works off sensors if the engine isn't running/cranking the pump is off.
akabond
May 28, 2011 08:17 PM
AnEskimo
Sep 22, 2010 07:28 AM
chaniewski
Nov 13, 2007 05:50 PM
jekelvin
Oct 5, 2006 11:36 PM
ReneVersteeg
Apr 4, 2005 08:58 PM
