the good ol' tranny questions
Old Feb 20, 2007 | 09:50 PM
98v70's Avatar
Default the good ol' tranny questions
For a 98 v70 non-turbo...DexIII is all I need correct? I'm thinking of changing some of the fluid by draining down at bottom..
Which are the vehicles that need that Mobil synthetic stuff and how can I tell which tranny I have? Asin/Warner or Geartronic....just some I found by searching.
I have a 4speed auto.. that might make a difference. I have no clue what transmission I have or what fluid to use. (Hope this dosen't stir up anything- just want some clarification)
Old Feb 21, 2007 | 03:59 AM
98v70's Avatar
Default RE: the good ol' tranny questions
I guess I should've read the owner's manual. Say's to use Dexron. I would still like to know what transmission I have though.
Old Feb 21, 2007 | 07:10 PM
v70 2.4t's Avatar
I'm would say you have a AW50-42, unless you have a turbo model
then it may be different...AW50-42 are the most common tranny for
that model, locate your tranny, should be to the right of the block, right down low you may have to dig a bit to find it.. there
should be a tranny plate on top...it will tell you for sure what tranny it
is.
good luck
v70 2.4t
Old Feb 24, 2007 | 08:11 PM
98v70's Avatar
Thank you! I will check when I change the fluid. What size is the washer for the plug? Do I need to get a new washer?
Old Feb 24, 2007 | 08:18 PM
I would get a newe one. It is an aluminum crush washer.
Old Feb 26, 2007 | 04:52 AM
98v70's Avatar
The job was very easy to do. I drained and flushed only once. I have 4 more quarts so I might drive alittle andflush one last time. Thanks for the write up by robert123.
Going through the gears in between drains I could hear the transmission clanking. Maybe because putting in 2 quarts after draining 3 or so quarts was not a good idea. It may be a good idea to just drain 3 and refill with 3, then flush.
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
86volvoguy
Apr 20, 2017 10:50 PM
Phil 850
Jul 25, 2012 10:01 PM
snoboarder_mike
Apr 4, 2009 12:03 PM
ponies
Sep 10, 2004 04:55 AM
