heating not working
Old Dec 23, 2008 | 11:44 AM
asadq's Avatar
Default heating not working
The heater panel on my volvo v70 dont work
we disconnected it, opened up the unit, couldnt see any problems with it
connected it back up and it worked until we turned the car off
When you start the car, the fan goes to full and then turns off within seconds.
some greeen/orange leds start to flash
what could the problem be
ive tried replacing the unit with another one and nothing!
Its getting VERY COLD [:@]
Thanks
Old Dec 23, 2008 | 12:15 PM
Default RE: heating not working
The lights flashing means there is codes in the system and possibly the blower motor or resistor is bad causing the lights to flash.
Old Dec 23, 2008 | 12:40 PM
asadq's Avatar
if i plug into a comp will i be able to draw codes?
Old Dec 23, 2008 | 01:14 PM
You need the program that will be able to read it. It is pretty expensive to get.
Old Dec 23, 2008 | 03:16 PM
asadq's Avatar
how can i diagnose if its the blower motor or resistor?
what do they look like and where are they
thanks
Old Dec 23, 2008 | 03:23 PM
They are under the dash on the passenger side. You will have to test power going to the resistor and see if anything is coming out.
Old Dec 23, 2008 | 08:23 PM
asadq's Avatar
how do i remove the dash
thanks
Old Dec 23, 2008 | 08:37 PM
There is a couple of t-25 screws holding the lower dash panel on.
Then you will need to open the glovebox and all those screws will have to come out. But before you remove the screws pop the plastic panel from the end of the dash. There is a screw that holds the shock to the glovebox door. Remove the screw and slide the shock off.
You could remove the top part but they usually break when you try to put it back on.
Old Dec 23, 2008 | 10:11 PM
HummerGuy's Avatar
Yeah, the way mine broke and is dangling there right now. Don't remove the top of the shock[&o]
Old Dec 24, 2008 | 06:56 AM
asadq's Avatar
right got it plugged in and it said motor fan current to high?
so i suppose its a new motor fan?
we also had a resistor lying around and swapped them over, same symptons
regards
Old Dec 24, 2008 | 07:16 AM
Yes it needs a new motor.
Old Dec 24, 2008 | 07:31 AM
asadq's Avatar
where can i get one from apart from volvo for £200!
and are they interchangeable between models?
thanks
Old Dec 24, 2008 | 07:45 AM
The motors will only be the same for the S60,V70 2001 and newer and S80 99 and up.
FCP groton sells them but not sure if they ship to where you are.
http://www.fcpgroton.com/product-exe...category_id/66
Old Dec 28, 2008 | 11:11 AM
HummerGuy's Avatar
Is this another issue that happens with alot of Volvos in general? Mine only starts making noises in the extreme cold so i'm going to wait to replace it until it dies all together or i cant stand the noise.
Old Dec 28, 2008 | 11:19 AM
Kind of but I think it is the setup.
Old Dec 28, 2008 | 11:43 AM
HummerGuy's Avatar
well, between the seat warmer and just the air that comes in from driving that would be enough to keep me warm for now. I dont use AC too much in the summer anyway. That's what moonroofs and windows are for.
Old Jan 14, 2009 | 04:33 PM
  #17
dknoth05's Avatar
Try changing the thermostat on the engine. I had a similar problem on my car. No heat would blow out of the vents even on high with temp turned all the way up. I replaced the thermostat on mine ...like a $6 part...now the heatworks great!!!
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
BigAdam
Oct 21, 2008 10:01 AM
maduko
Mar 24, 2007 07:57 PM
