Help w. throttle body !!
Old Jun 17, 2008 | 06:18 PM
martinz's Avatar
Default Help w. throttle body !!
Hi to everyone!
Every 30-40 k miles I have problem with throttle body and 'Performance Reduced' message. I would clean throttle body and it would run good for some time. Since cleaning doesn't help anymore I would replace whole unit. There is one on ebay for ~300$. Do I need to get the car to the dealer for proggraming or it's just smple part swap??
Please contact here or motomart@rock.com
Thanks, Martin
Old Jun 17, 2008 | 06:55 PM
mncx's Avatar
Default RE: Help w. throttle body !!
If got an eligible throttle u may qualify for volvo extended warranty. What's your mileage on your car? could still be covered under extended warranty. Even if warranty is out u should be eligible for software upgrade.Performance reduce message canset on message center for other issues too.Have to have codes to see what's wrong with it..
Old Jun 17, 2008 | 08:56 PM
martinz's Avatar
Thx for quick reply. I know it's waranted but I can't even get to the dealer. If I replace ETM is it going to start at all, stay stack in 'limp' mode or I'd be able to drive it?
Old Jun 19, 2008 | 06:48 PM
mncx's Avatar
I've seen it will set all sorts of codes in the system for the engine control system by just throwing a used throttle in... If u are lucky and get a throttle in a specific yr and comes of same engine and model as your car.. U may get it to work...The warranty have been extended fromVolvofor the theelectronic throttle moduleonly and it's for10 yrsor 200,000 miles whichever comes first.. It only covers 1999-2001 V70(ALL) or 2002 V70 (non-turbo)... Also make sure that your pcv system is not clogged. What is the current car u own?? mileage, model yr and engine would help.
Old Jun 19, 2008 | 09:40 PM
Woody30028's Avatar
The cruise control was failing on my 2002 V70. The dealer replaced the throttle body. I have no idea if they had to reprogram it.
Old Jun 22, 2008 | 02:16 AM
mncx's Avatar
ORIGINAL: Woody30028
Software must be loaded to a brand new throttle module. (2002turbo or all 03 and up will only need to initialize)
Sad850
Mar 1, 2015 01:05 PM
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
proudmonkey
Jul 21, 2005 10:01 PM
wavewright
Apr 9, 2005 06:15 PM
