weatherstripping
Old Jun 20, 2008 | 10:41 PM
sporky's Avatar
Default weatherstripping
I need to replace the rubber strip on the outside of the RR window. Its the seal on the bottom of the window. Not sure what exactly it is called, but the only place I could find something like it is from http://www.thevolvosite.com/V70/V70-...-moldings.html and they call it "moulding". Anyone with experience replacing this strip? Pretty straight-forward or special tools needed? thanks
Old Jun 21, 2008 | 06:47 PM
Default RE: weatherstipping
Sorry but which molding exactly?
Old Jun 21, 2008 | 10:53 PM
sporky's Avatar
Default RE: weatherstripping
Yep, kinda thought that my description was confusing...picture attached. The strip I need to replace it labeled #6. The picture doesn't show the right rear door that needs to be fixed, but it doesn't matter...all the windows have this strip.
Old Jun 21, 2008 | 11:23 PM
You need to do the outside one correct? If so it slides into a groove in the door. It will pull up.
Old Jun 22, 2008 | 08:56 AM
sporky's Avatar
yep, outside one. Do I need to remove the door panel or glass?
Old Jun 22, 2008 | 09:01 AM
No it should just pull up. Put the window down as far as it will go then you should be able to access some of it to pull up on it.
Old Jun 22, 2008 | 10:34 AM
sporky's Avatar
Installation is the same as removal...just press the strip into place?
Old Jun 22, 2008 | 10:58 AM
Yes it is.
97GLT
Sep 6, 2007 08:39 PM
volfan16
Jul 12, 2006 12:45 AM
