How do I take the valves out of the head?
I am trying to replace the valve stem seals, and I might lap the valves. I have the head off since I am replacing the head gasket. How do I remove the valves? Would this tool: https://www.harborfreight.com/universal ... 60335.html from harbor freight work?
Yes but you will have to use the threaded screw to compress and un- compress (is that a word?) each spring. Pretty tedious to do that for 20 valves. Compared to the style I showed where it's adjusted once, and you move the handle to compress the valve spring in one quick motion. Amazon has one like that for $5 more.
