How to replace door speakers?
Hey guys, im brand new to this forum, but i was wondering if anyone could tell me how to take off the door trip and/or be able to replace the speakers? im putting in a full aftermarket system (just put in a dvd head unit and a sub in the spare tire area) but i just need to figure out how to change the speakers..
Thanks for the help! =]
Edit: i forgot to say that its a 1998 v70 , Thanks again!
I'm guessing it's going to be the same as my 850 just because an 98 X70 is an 850 practically, but in mine, you just have to pry the speaker covers off the door, it'll seem like your breaking them, but it's just the clips popping out of the door. The rear deck speakers you have to take off four nuts from inside the trunk, and then the whole speaker/cover lift up inside the car, and then there should be four screws that on the bottom of the cover that hold it to the speaker.
![Smile](https://volvoforums.com/forum/images/icons/icon7.gif)
On my C70 the grills are attached to the door cards using speed nuts. You need to remove the door card to get to the back side of the grill (while still attached to the door panel) and loosen the speed nuts. Be careful when trying to remove the nuts, as they will break the plastic posts they are screwed to. You need to be very gentle.
I would definitely not pry on the grills from the outside. You will break them for sure, if they are like the ones on the C70's.
Hope this helps!
Cheers,
Ted
1998 C70 HPTM Saffron
Hope this helps!
Cheers,
Ted
paracitic
11-27-2007 04:42 PM
