want to replace door speakers
Old Apr 8, 2009 | 01:21 AM
dman777's Avatar
Default want to replace door speakers
on my 240 1989 volvo i want to replace the door speakers(front). I noticed the original ones are revited on. If I replaced those speakers, would I have to take the door panel off, or could I just drill out the revited ones and drill in the new speakers?
Old Apr 8, 2009 | 11:55 AM
TIPSP's Avatar
Got Boost?
It would be easier if you removed the door panel and installed regular screws....
Wait for others to respone.
Old Apr 8, 2009 | 12:34 PM
Somthngfrce's Avatar
+1 on that!
Old Apr 8, 2009 | 12:39 PM
mikkowus's Avatar
Heres how to remove the door pannel.
http://www.volvoclub.org.uk/faq/Inte..._Panel_Removal
Old Apr 9, 2009 | 12:58 AM
soundmiami's Avatar
as with most things Volvo, the speakers do not lend themselves to an easy modern US retrofit in both impedance and dimension. Be careful about how deep they go and the mounting holes and cover usually needs a mod. All this is far easier on a bench than in the door.
Old Apr 9, 2009 | 07:05 AM
dman777's Avatar
Really? Wow...I didn't realize that. Well, why I am on the subject I also plan on buying a pair of 6x9 for the rear dash, cutting out the holes in the deck and packing, and fitting in the speakers. I in the trunk in the metal frame there are two holes on each side of the car that look like they could hold 6x9 speakers. Am I correct that they can?
Old Apr 9, 2009 | 10:30 AM
TIPSP's Avatar
Got Boost?
If its not a direct fit.....you can always do a little triming.
Old Apr 10, 2009 | 01:29 PM
bruce t's Avatar
At least on the older ones (mine was 1979) they used 4" speakers in the doors. You should be able to drill the rivets out -- worst that could happen, they fall back into your doors. Also, IIRC, mine came set up for 6X9's in the back, and my 1991 780 had 6X9's. In the 240 I put some plate speakers in -- a 5.25" and a tweeter mounted in a plastic plate, and had plenty of clearance. But I think the cutouts were designed for 6X9's.
Cheers, bt
dizzy33
Apr 18, 2020 07:41 AM
88Volvo240
Jan 25, 2011 08:20 PM
DNytAftr
Nov 3, 2009 09:32 AM
yklin_tux
Mar 2, 2008 03:43 PM
paracitic
Nov 27, 2007 04:42 PM
