HVAC whistles Help!
Old Sep 12, 2008 | 05:27 PM
lotusing's Avatar
Default HVAC whistles Help!
I have a 99 V70 that when the a/c is on the blower whistles.When turn the a/c off and keep the blower on, it stops.I replaced the cabin filter and it still does it.What is wrong?
Thanks
Old Sep 12, 2008 | 08:03 PM
Default RE: HVAC whistles Help!
Does it also do it after you have the car turned off?
Old Sep 12, 2008 | 09:27 PM
lotusing's Avatar
Thanks for the response. No.If the fan is off or on it will not whistle. It only makes the noise when the a/c button is pushed and the blower on.
Old Sep 12, 2008 | 09:39 PM
Does the noise sound like it is coming from inside or outside?
The Orfice tubes tear and whistle when the compressor comes on or goes off.
Old Sep 13, 2008 | 01:31 PM
lotusing's Avatar
Definitely inside the car.
Old Sep 13, 2008 | 02:24 PM
Also see if you can hear it outside with the hood up. If it is the orfice tube you will be able to hear it under the hood about 1 foot from the firewall Passenger side.
Old Sep 14, 2008 | 12:04 PM
mr maraki's Avatar
Hey tech can you tell us more about the orifice tube? Mine whistles like a steam train turning on and off! It doesn't seem to be leaking though?
Old Sep 15, 2008 | 04:25 PM
When they do this it makes it whistle. See pic. The 2 on the left are bad the right one is new.
Old Sep 15, 2008 | 10:07 PM
lotusing's Avatar
Sorry, I could notgetto the computer. You are saying to listen on the outside to find the source which may be the orifice tube? If it is it, I would lose all the freon in the system to change correct?
Thanks again
Old Sep 15, 2008 | 10:12 PM
Yes
And yes you would need to drain the system to replace it.
Old Sep 16, 2008 | 06:57 PM
lotusing's Avatar
Thanks tech. I will work on it this weekend.
worldbound4now
May 17, 2012 10:50 PM
lotusing
Jul 17, 2009 10:03 PM
850forum
Feb 25, 2007 01:51 AM
robert213
Apr 30, 2006 06:33 PM
Air Defender
Mar 2, 2005 02:29 PM
