I need Help
Old Oct 14, 2011 | 10:37 PM
WKend Tuner's Avatar
Default I need Help
Hello fellow V70 drivers and tuners. I need help. I have a B5254S and I want to put the B5254T headers from Viva performance on it. With a high pressure turbo and the 3" stainless IPD turbo back exhaust; then pipe in the GLT intercooler and redo up my intake system to receive the cold side pressure from the new turbo.
Will that exhaust set up bolt to my block? What else do I need to do to the cold side system so that the fuel mixture keeps up with the new pressure? I figure new injectors, air flow sensors from the "R" model. Will I need a new ECU? Are those GFChips programmable for this type of upgrade, or will I need a programmable system from ipd or viva performance to make the engine run properly. I am not look for super power but would like to get well into the mid-300hp range. I would also like to go with the boost coil iPD ignition plugs, will I need something with more kick? How much will I need to upgrade to make all this work?
Would I be better off to find a rear-ended V70R and just swap blocks and go from there?
I am very open to suggestions. Has anyone out there done something like this before?
Thank you for any help.
andrei3333
Dec 26, 2010 10:22 AM
Sanel30
Feb 18, 2010 09:16 PM
texan_176
Oct 4, 2009 10:05 PM
chef
May 19, 2009 05:57 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
