idling speed high???
Old Dec 7, 2011 | 04:39 AM
boletole's Avatar
Unhappy idling speed high???
just noticed idling is bit high on my v 70. what could be a cause of this? what would you recommend as a cheap and easy fix to this problem?
thanks in advance for all the assistance provided
Old Dec 7, 2011 | 09:03 AM
What is the rpm running at? What has changed lately? Is it possible that AC is on and causing a slightly higher RPM?
Old Dec 7, 2011 | 01:55 PM
boletole's Avatar
Unhappy idling problems
thank you for you reply
i never used air con because i hate it,it is running at about 900 rpm when placed in drive and also when placed in neutral it seems to go even higher.
what should be a normal range of operation?
Old Dec 7, 2011 | 01:56 PM
boletole's Avatar
it stick a about 900 and 1000 rpms..
too high i thought so.
Old Dec 7, 2011 | 09:45 PM
Yes, that sounds high. Anytime you put the defroster on the ac comes on, you have no control over that.
Not sure what would make these cars idle high other than if there is a vacuum elbow torn or loose. Hopefully someone else will come in and help.
T5-R
Oct 31, 2012 12:30 PM
itr
Nov 22, 2010 07:05 PM
v0lv085o
Sep 9, 2010 06:23 PM
Frejborg
Feb 8, 2009 06:25 PM
parrym
Nov 7, 2004 11:30 AM
