Its me again..!!! labour involved
Old Jun 12, 2006 | 04:37 AM
v70 2.4t's Avatar
Default Its me again..!!! labour involved
I guess this one is for Tech, how many hours labour involved in oil pan o-rings..
Did i read in a post that you lost your job!! What happened??
v70 2.4t
Old Jun 12, 2006 | 08:50 PM
Default RE: Its me again..!!! labour involved
One day I will have to update that.
That was almost 2 years ago that I lost my Job.
I am at an Indy shop not that only works on Volvo's.
The labor is about 8 Hours or so.
Old Jun 13, 2006 | 12:19 AM
Moparman's Avatar
8 hrs, holy fawk.........whats with the orings? This cause an internal oil leak? This something else to look forward too?
Old Jun 13, 2006 | 06:00 AM
v70 2.4t's Avatar
Had the car towed to volvo dealer, "no oil pressure stop asap" fickering on and off.
i called today, they say that they have sent a e-mail to volvo Austraila tech support, asking for likley senario's. The Tech at the dealership said it might be the oil pump ? 8 hours labour, said he needs to lift the engine up about 1 foot to drop the sump? cross menber in the way...is this correct..??
v70 2.4t
Old Jun 13, 2006 | 07:43 PM
That is correct.
Moparman The o-rings go between the oil pan and the Bolck. They seal the oil pan to the block for good oil pressure.The pickup tube goes into the block but the passage goes through the oil pan.
When the o-rings go bad it looses some oil pressure.
Old Jun 14, 2006 | 03:30 AM
v70 2.4t's Avatar
They are going to drop the oil pan today, and change the oil pan o-rings.
Crankshaft seal was leaking very bad, they are also going to take the caps of the bearings to
check for damage.
$554.00 Aus dollars, not to bad, hope there is no bearing damage..
i'll keep you all posted..
v70 2.4t
Old Jun 14, 2006 | 10:36 AM
Thanks for the update.
Old Jun 15, 2006 | 04:20 AM
v70 2.4t's Avatar
spoke to volvo dealer, bearing one great shape, bearing 2 in great shape, 3 had a bit of pick-up on it, no major drama, normal wear , 4 & 5 also great shape..
4 o-rings in the oil pan were totally smashed. Dealer said its from poor service history(not on my part i change oil every 5,000km).
car will make a full recovery, im happy.
it comes home Monday.
i'll let you know how it runs.
v70 2.4t
Old Jun 15, 2006 | 10:18 AM
Glad it wasn't major.
Old Jun 19, 2006 | 04:11 AM
v70 2.4t's Avatar
Oil pressure is 3 bar as tested by volvo tech which is normal he tells me?, oil light flickered in fifth gear while he test drove it,
he said the oil pressure switch might be gone, could it be another problem ? ,
or any other senario.
v70 2.4t
Old Jun 19, 2006 | 08:54 PM
Might be the switch.
He needs to make sure the oil pressure doesn't fluctiate when driving.
Old Jun 21, 2006 | 02:57 AM
v70 2.4t's Avatar
ok, oil pressure switch replaced, light still coming on, oil pan o-rings replaced, switch replaced,
no knocking sounds coming from engine, any ideas ???
v70 2.4t
Old Jun 21, 2006 | 08:41 PM
The pressure must still be going to low.
Maybe the oil pump. That would be the next guess.
Old Jun 22, 2006 | 03:46 AM
v70 2.4t's Avatar
Yep spot on, thats where they are going next !!
i'll keep you posted..
v70 2.4t
Old Jun 23, 2006 | 06:32 AM
v70 2.4t's Avatar
they are going in to the oil pump monday, if the oil pump is visually stuffed the will assume that is the problem and replace it, if the oil pump checks out good, there advise is a blockage in one of the galleries, any advise to clear the blockage at this time would be great.
v70 2.4t
Old Jun 26, 2006 | 10:01 PM
Flush the engine with a good engine flush.
Old Jun 27, 2006 | 03:43 AM
  #17
v70 2.4t's Avatar
Hi, Engine flushed today, oil drained, refilled.
light came on again 1/2 way down the road.
the car is not making any knocking noises at all, the pressure is starting out at about 2.5bar,
then drops to about .5bar under acceleration , the volvo tech's are quite confused as they say that it should be knocking or something.....
where do you think they should look next...
Two days before the flush they got into the oil pump it was full of varnish, they cleaned it and replaced a seal in the pump, all was good three times around the block all good then bang .5bar again
Any idea's would be great.
V70 2.4t
Old Jun 27, 2006 | 08:25 PM
  #18
If they didn't replace the PUMP I would say that is the problem.
Next would be to take the engine apart and inspect everything.
Old Jun 28, 2006 | 03:38 AM
  #19
v70 2.4t's Avatar
ok, light off but they had to use a thicker viscosity oil, 40-70,.
they said oil pump was ok when cleaned. they say its not the problem..
they say the motor is varnished up.
thanks for your help Tech, if your ever in oz drop by for a beer!!
v70 2.4t
Old Jun 28, 2006 | 09:47 PM
  #20
Yes keep me posted on how it goes.
