Key stuck in ignition
Old Aug 9, 2007 | 07:46 PM
TonySeal13's Avatar
Default Key stuck in ignition
Okay so one day you just try to park your car. You put it in park,and you turn off the car off , but you cant seem to take out the key.
This is a big problem becuaseyour car has to remain open.
with the key still there...
this is open to car theft.
What could the problem be.
" i think its the the clicker on the shift **** handle for Automatic cars."
any other possible ideas please help >.<
Old Aug 9, 2007 | 08:23 PM
b5254t's Avatar
Default RE: Key stuck in ignition
You did not specify year but if it a 99 or 00 model check the shifter ****. They like to break especially the lower right corner. Try pulling it out all the way then release the key. Good luck.
Old Aug 9, 2007 | 08:55 PM
TonySeal13's Avatar
oh sorry its a 98 V70.
Ijust took a look at it and your right its broken.
a peace fell off the lower plastic part of the **** and when i try to pull it out, it seems its stuck. i tryed to pull it out but the one side seems to be stuck or jammed.
i dont wanna break it anymore should i get a volvo tech to check it out?
Old Aug 11, 2007 | 08:38 PM
b5254t's Avatar
If you are not sure what your doing it would be a good idea to have someone familiar with volvos look at it. You can try pulling the **** out or if you want the key out you can pull straight up on the shifter **** and it wil come off. then you should be able to release the key,assuming this is your problem. good luck
Old Jul 11, 2013 | 10:55 PM
Obelix
Jun 20, 2022 08:40 AM
dodgerkcj
Jul 2, 2018 11:41 AM
amotin
Dec 12, 2008 09:13 PM
nandrolone
Oct 3, 2005 01:55 PM
