Lemon?
Lemon?
Hello! I am a new user to this board, but have owned Volvos for a long time. My wife (before I met her) bought a V70 (non-turbo and US-spec) directly from the factory. It has burned a LOT of oil since new. Dealers in Germany and the UK, as well as Volvo NA all say that this is "normal"
About 2 years ago, we replaced the first burnt valve...very, very expensive. Since then, we have replaced 2 more valves and are now replacing a main seal. The car runs rough, and burns a quart of oil every 200 miles or less. We can't really sell it in good faith, and will probably just end up selling it for scrap value since the engine it has is not easily avaiable (used) here in the UK.
Anybody have similar problems?
RE: Lemon?
We have lots of documentation. Even with that, the local Volvo dealship, Volvo Corporate and Volvo North America all tell me that the oil comsumption is "normal". Now it is way out of warrenty and I am convinced that the problems we are having are because of whatever is causing the oil consumption. Trouble is, while eveyone agrees that the burnt valves are abnormal, noone is trying to find the root cause of the problem.
Guess we will run it till it dies again, then scrap it. Too bad, because the car is in excellent shape.
RE: Lemon?
One last shot since Volvo Corp. is not owning up to a lemon (my opinion). Does this car have to pass a smog check? Most state laws require the manufacture to be able to pass this check up to a certain number of years. I'm not all that informed on this subject, but really feel you are being handed poorly, and this might be an edge to get a response. I wish I could be more helpful, it seems this is all based on "opinion", and mine is just as good as anyone's elses! I hope you can do some research on this and this might help.
Jerry
01 V70 T5a
Jerry
01 V70 T5a
RE: Lemon?
I have owned both the old B20 engines (had 370K miles) and the newer 5 cyl engines (a paultry 91K miles), and have no issues with either. You have a lemon, and I am very disssapointed you can't resolve this with Volvo. My faith is shaken. I wish there was moreI could do, but I'm thoughtless.....
Jerry
01 V70 T5a
Jerry
01 V70 T5a
