Lights out
I have need to run "lights out" in my job and was wondering if there was a Daytime Running Lights relay I could modify or switch out to accomplish this. I've done this on other vehicles and was able to use lights normally. Any suggestions?
Thanks
Thanks
You can manually set the daytime running lights off in the 1998-2000 models. There's a small "flat head" screw located on the lower right hand corner next to your headlight switch on the dash. If your daytime lights are on the screw will be in a verticle position. Use a small screw driver and turn the screw to the left to 10 O'clock and this allows you to disable the daytime running lights
ewgoforth
Jul 29, 2012 09:45 AM
benschumacher
Aug 13, 2010 02:43 PM
chrystald423
Mar 27, 2010 08:05 AM
