littele heat and low temp gauge-thermostate problem?
Old Jan 9, 2010 | 09:28 AM
Bmahoney's Avatar
Default littele heat and low temp gauge-thermostate problem?
'02 v70 temp gauge doesn't go above 1/4 i cold weather (20 degrees) and the heat is minimal- check engine light is on- where should I start
Old Jan 9, 2010 | 06:34 PM
icp's Avatar
icp
I have the same problem with mine. I just finished replacing the thermostat. I had the check engine codes read and it told me a cold engine. Works fine now and I have heat. It was 3 degrees this morning. It was an easy fix.
Old Jan 9, 2010 | 06:39 PM
JTapper's Avatar
Thermostat is likely stuck open.
Old Jan 9, 2010 | 08:27 PM
family XC70's Avatar
Replace your thermostat. They are relatively inexpensive and very easy to change. This will more than likely solve your problem and give you heat.
Old Jan 10, 2010 | 09:05 PM
piercebrew's Avatar
Hey same problem here. Where is the thermostat located? I have an S60 2001 2.4T.
Thanks.
AnEskimo
Mar 7, 2014 08:29 PM
blackbrick
May 7, 2011 01:46 PM
wmallick
Nov 16, 2009 02:04 PM
vcolper
Nov 1, 2006 10:20 PM
