Lug pattern & offset
Old Feb 6, 2009 | 09:48 AM
Platinum52's Avatar
Default Lug pattern & offset
Does anyone know what the offset & lug pattern is on the 16" wheels for the V70?
I was looking for a cheap set of OEM's for spring/summer/fall tires and realized you can get ridiculously cheap aftermarket rims for just about what OEM's cost new......
Old Feb 6, 2009 | 01:34 PM
TIPSP's Avatar
Got Boost?
Most Volvos from whenever to current (except the 93 4 bolt wheels), use the same bolt pattern....5x108. and the offset for the FWD Volvos is ~43mm.
Old Feb 6, 2009 | 02:53 PM
Platinum52's Avatar
5x108 and 43mm. great - thank you!
Old Feb 6, 2009 | 03:04 PM
TIPSP's Avatar
Got Boost?
No Problem.
Old Feb 6, 2009 | 06:39 PM
Somthngfrce's Avatar
OK, TIPSP and everyone else...Here's a question for u since we are on the Subject of wheels and offsets! I have a set of Volans in the garage that I am planning on putting on the 850. However I fell in love with a set of wheels off a S40/V50 (2005 I think). They are known as STYLLA. They are 17x7.25 and offset is 52.5? I am trying to figure out if they will look right on the 850. I am buying them Super Cheap! BUt is this a waste of time and money. I think they will look sweet. What's your 2 cents?
Here's a link to a wheel http://cgi.ebay.com/ebaymotors/VOLVO...Q5fAccessories
Old Feb 6, 2009 | 08:18 PM
TIPSP's Avatar
Got Boost?
Honestly...save the money for something else!
I love the look of the Volans on the 850s!
Assuming that it is the same bolt pattern. It should be 5x108.
If you do get the wheels, you would have to check if they rub.
Then all you do is get ~10mm spacers from H&R and call it a day.
Old Feb 7, 2009 | 10:10 AM
I have seen people running them. I think you will be fine without spacers.
If you buy them we can work a deal out for the Volans!!
ltruong81
Mar 14, 2015 02:10 PM
mikethedrummersca
Oct 28, 2009 05:08 PM
Cobra Jet
Jan 31, 2008 03:53 PM
Scruggs
Aug 23, 2007 03:31 PM
