Mysterious Coolant Leak Wrong Forum Sorry
Old May 30, 2008 | 01:12 PM
pjlapl's Avatar
Default Mysterious Coolant Leak Wrong Forum Sorry
I posted to the wrong forum Sorry
Mysterious Coolant Leak 2001 V70 93k I have developed a coolant leak, which I can’t trace and the occurrence is random. No correlation between drive time and leak. Actually seems to leak more on shorter trips. There will be no leak for 2-3 days and then the overflow reservoir will be drained on the next trip. The hoses are tight. At times there is a small puddle on the ground under the driver’s side front headlight. 2-3 ounces. Temperature gauge is constant. No sounds of a pressurized leak. Repair shop says time for a $750 replacement, but because of location they really can’t get a good look. I suspect they will not investigate, and just replace. Suggestions???/ Many Thanks,
drabina
Jun 30, 2013 01:00 PM
trooperone
Nov 9, 2009 08:38 PM
pjlapl
May 30, 2008 06:16 PM
Blaiz
Sep 1, 2007 11:38 PM
wcharris
Jul 29, 2005 12:50 AM
