Mystery Oxygen Sensor
Old Sep 21, 2010 | 03:50 PM
jayistall's Avatar
Default Mystery Oxygen Sensor
Hello. Great Site!
I have a 1998 V70 non-turbo.
Check engine light came on shortly after having my small shop mechanic replace the engine with one that was 130k miles. (I blew the other one). Runs good again. Check engine light pops on. Codes are Oxygen sesor P132 and P135. Basically not working. I looked for it myself and noticed the 4 wires leading to the plug from the car had been pulled from the connector which plugged into the opposing connector going to oxygen sensor 1. Upstream. He said I needed a new sensor. I let him do it even though I also explained the wires were "out". I assumed they got pulled when they replaced the engine. New sensor and check engine is back on. Same codes. I asked about the wire leads and he assured me they were put back correct. But he could not solve the riddle. He took it to Volvo dealer and they fiddled with the plug, charged $100 and 2 minutes later the check engine was back on with same codes. They want several hundred now to figure it out. I have been looking for some wire diagram to show me which color wires hooks up to the plug in correct sequence so I can try for my self. Any ideas where I can find these colors? Thanks.
Old Sep 22, 2010 | 12:43 PM
jayistall's Avatar
Default check engine light
so let me get this straight..the check engine light is on now. Showing 2 codes regarding the oxygen sensor 1 (upstream as you call it). And that is after you had the new sensor put in?
Old Sep 22, 2010 | 12:44 PM
jayistall's Avatar
yes. that is correct.
Old Sep 22, 2010 | 12:45 PM
jayistall's Avatar
hmmm. what did your mechanic and the dealership say about your story on the wire leads being pulled from the connector?
Old Sep 22, 2010 | 12:46 PM
jayistall's Avatar
they just shrugged and said that was not a problem. But I am not clear that the dealership checked the seqence of wires in the connector after the small shop mechanic shoved them back in?
Old Sep 22, 2010 | 12:47 PM
jayistall's Avatar
I see. That is a mystery. What is the question again?
Old Sep 22, 2010 | 12:52 PM
jayistall's Avatar
well..what I want to know is why is the check engine light coming on with 2 oxygen sensor codes when I just had it replaced? Incidently I know it is the same codes because I have a nice handheld computer I bought from Harbor Tools.
Since I don't have much confidence in the small shop now...and can't afford to pay $90 and hour (3 hr min) for the dealership to do investigative analysis (particularly when I spelled out my concern over the wire sequence) I would like to learn which wire color lead goes in which plug hole. There are 16 diff combos. Surely there is a wire schematic someplace with color coded descripts of the plug wires for crying out tomatoe sandwiches!!!
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
98XCFxRUpR
Oct 4, 2010 12:37 PM
netflash
Jan 31, 2005 07:56 PM
