Need A/C Help
Old Jun 17, 2008 | 12:49 AM
acfella's Avatar
Default Need A/C Help
Hi Guys,
I am having a problem with my A/C. I have a 98 V70 non turbo, with electronic climate control. The problem I am having is the A/C blower will run very slowly or stop all together. What happens is when I first turn the car on I usually have the A/C on 72 and auto, the fan will ramp up to full speed and after a few minutes it will ramp down to a very slow speed, shut off, run at a slow speed, run full blast and so on. I know my compressor is still running because I can hear the clutch pulling in and out. So I have concluded it is either the blower motor or motor resistor, but which one. Do you know of a trouble shooting method as opposed to trial and error. Any help you could give would be much appreciated.
I live in Phoenix, AZ and it has been 110+ for the last few days and basically the car is non driveable.
Thanks alot for the help.
Bo Rogers
ps, I have an evaporative leak, I can hear the bleed down up front, any ideas there.
Old Jun 17, 2008 | 05:53 PM
Eric J's Avatar
Default RE: Need A/C Help
I bet it it the blower motor, mine was doing the same. Easy fix.
andrei3333
Dec 26, 2010 10:22 AM
Sanel30
Feb 18, 2010 09:16 PM
texan_176
Oct 4, 2009 10:05 PM
chef
May 19, 2009 05:57 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
