Need Help Quick Install Half Shafts
I'm right in the middle of replacing the driver's side half shaft (axel). Everything came apart exactly as the instructions said. Now I'm putting the shaft back into the transmission, and it won't go! I can feel the splines line up but it won't go in all the way. I've lightly tapped on it when I had it straight, but still no go. So what's the trick?
While I have new lower ball joints I was going to put in while I was in here (doing the lower A arm as well), I can't get the old one out (the A arm is removed, and so are the 2 12mm head bolts). I've tapped on this with a drift and again no go.
Thanks for the help, I'll try the archives, but I had looked pretty extensive before I started, and didn't see any thing on problems getting this back together.
Jerry
Jerry
pinky
Jul 12, 2013 10:56 AM
Annihilator
May 19, 2011 05:56 PM
