Need urgent help with urethane upper torque mount
Hello,
I ordered a replacement upper torque mount, didn't want the OEM one based on how often they deteriorate. Now I'm wondering if something is wrong. I took out the stock mount and upon installing the urethane mount, it seems like it's too loose. The bolt holes are offset so you can twist either of the two urethane pieces either clockwise or counter-clockwise, and if I do that it becomes tight, however with both of the holes lined up dead even i can pass the urethane mount right through the bracket without even separating the two halves. Is this normal or did I get a defective mount or something? I made sure to purchase the right model, the one for the aluminum mount bracket on the head, not the one for the steel bracket that goes on the side of the motor. I could really use some advice on this because now I can't drive my car until I figure this out. Thank you!
i just ordered IPD's version, which is what i should have done before but I found this other one first and it said it fits any model v70. this is so stupid, i can't even drive my car now. i got the first one from volvomotorsports.com. it even says on their site it fits any model. LIES. LIES. DSAFKJDSLKJ im angry.
update:
waiting on correct upper torque mount from IPD, should be here saturday I hope. spoke to owner of VMS he is a nice guy honored refund and paying for return shipping also, he said he would give refund soon as i give him tracking #. spoke to IPD 2 times today, once to make sure its the right mount they're sending, and it is, and once to make sure they shipped it today. supposedly delivery time is 2 days.
now i wait....i'll let you know how the install goes...
Hello,
to comment on above post, maybe they did not torque the bolt down properly. 36 ft-lbs is pretty tight and really shouldn't just come off like that.
and i got mine done today. ipd's version fit nice and tightly. i gotta tell you this is a really good and simple upgrade. they claim it may have more vibration, but honestly the only time it vibrates more is when i am cranking it up. otherwise it actually feels smoother. transmission shifts are definitely crisper as well and no more downshift clunks or off-the-line vibrations either. maybe it's vehicle-dependent on how good the results are with these urethane mounts?
the stock mount was shot, rubber was completely separated from the plastic surround. i'm sure this was the cause of the above problems, and replacing it with another OEM one would probably solve them about as well, but my feeling is that not only is this a lot less expensive, it should last longer too. can't beat that!
