Is oil on spark plugs an issue?
Old Jun 18, 2010 | 11:02 PM
ShawnM 02 V70's Avatar
Default Is oil on spark plugs an issue?
Just recently replaced my spark plugs to complete tune up since purchacing the 02 v70 T. I noticed that three of the 5 spark plugs had oil on the threads. The electrodes didn't seem to have much on them however. The other two were relatively clean. I suspect that the plugs had probably been recently done as the gap was still a tight .028 and they looked pretty new. Is this something I should be concerned about?
Thanks, Shawn
Old Jun 19, 2010 | 10:49 AM
SVTfocusO3's Avatar
It depends I gues where it came from, a new oil cap gasket helps keep it out of the top, but a miniscule amount is not really bad i guess for a turbo. have your oil trap checked?
Old Jun 19, 2010 | 10:47 PM
There isn't that much. It's like someone brushed some oil on the threads instead of an antisieze compound. It doesn't look as though there has ever been oil leaked in from the top via a faulty gas cap. Pretty clean! When inspecting the oil trap what am I looking for? That the two lines aren't clogged or am I openning it up for a peak inside?
Thanks, Shawn
Old Jun 19, 2010 | 11:02 PM
SVTfocusO3's Avatar
thats what i was thinking, just did some spark plugs the other day, and same thing, no problem. Now the oil trap, i dont think you have the correct tool to check it. you check it at the dipstick with a vacuum gauge, a miniscule vacuum gauge is needed as it there is barely any there, pressure there indicates a clog. usually at the banjo bolt on the intake and the skinny hose from it is where oil dries up. it can be cleaned, but usually a new hose is needed, as its brittle. your dealer has the gauge and i am sure if you ask them, they will do it no charge.
Old Jun 20, 2010 | 01:14 PM
checksix's Avatar
To check if the dipstick is "sucking" I've used the smoke of a blown out candle, or what ever else you have handy.
Jerry
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
NYSpeedRacer
Jun 5, 2008 05:31 AM
dcox612
Sep 29, 2005 09:37 PM
