Overheating and CEL
Old Nov 9, 2006 | 02:01 AM
MtnVolvoWgn's Avatar
Default Overheating and CEL
Hi everyone. I'm new here and am hoping to get some help. I have a 1998 V70 Wagon that is running hot. Temp guage is in the middle. CEL is on and it is throwing a P0116. Is this a thermostat or is there another temp sensor that I don't know about.
Old Nov 9, 2006 | 08:46 PM
Default RE: Overheating and CEL
I would inspect the thermostat and maybe even replace the temp sensor in the thermostat housing.
Old Nov 22, 2006 | 03:23 PM
Ok, replaced thermostat but still running hot. Losing coolant, but I can't tell where. No obvious leaks.
Where should I look next? Water pump? I'm praying to the Volvo gods that it's not head gasket or something horrible like that. Just went through that mess with my Land rover.
Old Nov 24, 2006 | 11:21 AM
Make sure the oil doesn't look like choclate milk. If it does then the headgasket is gone.
I think the headgasket is bad and thats why it keeps overheating.
Old Jan 9, 2009 | 05:53 PM
Sailing_Faith's Avatar
Amazing,
I was getting a P0116 code so I bought a new sensor. I really did not think it was bad, as the dash read out was pretty linear from start up.... but since I read they go bad I figured it was time.
I removed the sensor, and it looked ok, it was stamped 'Volvo' but the car had been dealer maintained up to 99k so it may have been changed before.
I opened the thermostat housing, and was amazed to find the German "Waller" thermostat (also stamped volvo BTW) had actually BROKEN. The braces that secure the springs to the gasket plate are the failure point. One side seems to have cracked loose at the base, and the other side is bent. The thermostat would neither fully open or fully close in this condition.
I have read others have problems with these 'waller' thermostats also FWIW.
[/align]
matt01
Jul 23, 2012 11:12 AM
Arsenal6
Feb 8, 2009 08:11 AM
meghuzzah
Jul 28, 2008 01:27 PM
mtidwell
May 2, 2006 09:15 PM
