P0573 - Brake Switch A circuit high
Old Apr 21, 2006 | 02:52 PM
sk799's Avatar
Default P0573 - Brake Switch A circuit high
Hi
Just had this error code come up on my 2001 Model year V70. Has anyone else experience this? My cruise control also stopped working approximately 2 weeks before this error message appeared. When you switch the cruise on it still displays in the dashboard but you just can't set the speed. Is it likely they are related?
Is it one combined switch for the brake lights and the switching off of the cruise control?
There are 2 codes, one for 'circuit high' and a different one for 'circuit low'. Is there anyway of telling specifically what has failed from each of these different codes?
Thanks for all your help
Stuart
Old Apr 21, 2006 | 09:13 PM
Default RE: P0573 - Brake Switch A circuit high
There is a switch in the Brake Booster. That switch is bad. It is a cylinder looking thing with a plug on the end.
Old May 3, 2006 | 08:33 PM
sk799's Avatar
I replaced the brake sensor and removed the stored error code. Unfortunately the cruise control is still not working though.
Any further suggestions?
Thanks
Old May 3, 2006 | 09:49 PM
The code might still be present in another computer not allowing the cruise to work.
Old May 4, 2006 | 01:49 PM
sk799's Avatar
Is there anyway I can check if this code is present in another computer or will I have to take it to the dealer for them to find out.
Thanks
Old May 4, 2006 | 09:02 PM
Sorry but the Dealer. Or an Indy that can read all the computers.
grndslm
Jul 7, 2012 03:09 PM
ivx675
Mar 27, 2010 01:36 PM
likesspace
Jun 16, 2007 06:01 PM
Shartzy4
Apr 8, 2007 07:33 PM
dave_n_s
Oct 11, 2005 10:31 AM
