Please help
Old Apr 27, 2018 | 01:45 PM
Luke Berringer's Avatar
Default Please help
Does anybody know why my v70 would have a squeak in the motor that stops when you pull the oil dipstick?
Old Apr 27, 2018 | 06:08 PM
clogged PCV system. when you pull the dipstick it allows the pressure to be released. See if the noise also goes away if you loosen or pop off the oil filler cap
Old Apr 28, 2018 | 07:42 AM
Georgeandkira's Avatar
Year, mileage and trim level always helps.
What's your APPROXIMATE location?
Old May 5, 2018 | 09:37 PM
LinkFL's Avatar
PCV system. This is a very common issue, that is usually diagnosed by removing the oil fill cap or dipstick.
Old May 13, 2018 | 08:41 AM
Welcome to VF Luke.
Remove to inspect the black tank (PCV). Some times it's not the black box but poor maintenance and oil change that allows the passage in the oil pan to get blocked rendering the PCV system inoperative. The boxes port can get clogged too.
https://www.google.com/search?q=clea...hrome&ie=UTF-8
Attached Thumbnails Please help-pcv-oil-pan-passage-blocked1.jpg   Please help-pcv-cutaway.jpg   Please help-pcv-box-plugged-port.jpg
Old May 13, 2018 | 11:40 AM
ssicarman's Avatar
Year and engine?
mrlefler999
Mar 8, 2021 02:07 AM
MNWILD
Sep 10, 2020 11:29 AM
ericsb210
Mar 30, 2010 09:43 PM
Sanel30
Feb 18, 2010 09:16 PM
Epr7339
Jan 6, 2007 12:25 PM
