Replacing AC switch on Console Tech?
Is it easy to replace a damaged A/C (manual/automatic) switch on the center console? I understand you pop off the pen holder then undo a couple of screws to get to the climate control unit. Do you have to remove the whole climate control unit to access this button?
Thanks.
Liz
Thanks.
Liz
RE: Replacing AC switch on Console Tech?
it's not too bad a job, I've just had mine out to replace the bulbs, just two torx screws behind the pen holder and then considerable force to pull the ccm downwards away from the radio. Watch how you put the torx screws back, if you drop them they are lost ( I lost one!!!)
good luck les k
good luck les k
