Replacing Factory Radio with Aftermarket
Old Sep 10, 2008 | 06:50 PM
VolvoCyclist's Avatar
Default Replacing Factory Radio with Aftermarket
I just bought a 2002 V70 2.4 and I was wondering if there is a dashkit that I can get to replace the factory radio (since it only has a tape player...) with an aftermarket unit (either standard or double DIN). If so where can I find a cheap dashkit and wiring harness? Anything else special that needs to be done as well?
Old Sep 10, 2008 | 11:30 PM
samadkins29's Avatar
Default RE: Replacing Factory Radio with Aftermarket
Well the dash kit is standard. Its a standard radio size. Now if you want one din with a pocket or double din thats up to you. Wiring harnesses can be bought at best buy for under $20.
Old Sep 16, 2008 | 02:32 PM
Rascal2pt0's Avatar
you can also find cd units. I picked up one with a CD player in it and just swapped it out tape only unit.
Old Sep 16, 2008 | 03:00 PM
I have the CD and tape unit, but to play my iPod I had to use the cassette adapter which I could not stand. What I ended up doing was just getting the factory unit iPod adapter from a local electronics store and had them install it; I did not want to mess up the whole computer system, plus the factory speakers do not sounf that bad.
emerlin
Jul 28, 2016 11:19 PM
yabani
May 30, 2009 03:16 PM
viriiguy
May 15, 2008 01:34 PM
m4gician
Jan 2, 2007 03:11 PM
