S/V70 Door Handle Help
Old Oct 7, 2012 | 11:14 PM
ProStreetDriver's Avatar
Default S/V70 Door Handle Help
So I picked up 4 S/V70 door handles for my 850. Also doing a lock delete too Now they aren't the same color as my car, so I have to paint them. I'm trying to split the pull part from the stationary piece and I've already popped the spring out. But this little brownish plastic clip is still holding it together. I was able to pop it up, wiggle it around, but I'm still having trouble. Any help would be greatly appreciated.
Old Oct 7, 2012 | 11:47 PM
Never mind, I just figured it out lol. I posted on a couple other forums with no luck about a month ago and I didn't realized I hadn't made a thread here to ask anyone. But I just figured it out tonight accidentally.
For future reference if anyone ever has to do this I'll type up a little tutorial here. Hopefully it'll make sense and it isn't too hard to follow without graphics. I will end up making a video on it so someone can use it as a reference in the future
-Remove the spring
-Remove the rubber gasket from the handle (Might be able to do without removing the rubber, but this is how I did it)
-Close the handle all the way past the stationary piece
-Pull handle and stationary piece away from each other once you're in that past close position
-Then remove brown colored clip (Pulls straight out from the back side of the handle. Has 2 clips which can be seen by 2 small holes)
-Leave handle in that "pulled position" then continue to pull the handle as if you were going to open the door.
And there you have it, it's apart!
madmattd
2001-2013 model year V70
Jan 16, 2014 08:32 PM
ProStreetDriver
1998-2000 model year V70
Oct 12, 2012 10:32 AM
ProStreetDriver
Oct 12, 2012 10:31 AM
TMac
Apr 23, 2009 09:21 AM
andrewlittell
Dec 10, 2007 07:39 PM
