Sizing of snow tires
Old Dec 20, 2007 | 04:52 PM
Glenn B's Avatar
Default Sizing of snow tires
I have a 1999 T5 wagon with 205/55/16 all season tires.Is there a problem with clearences or braking if I use 225/60/16 snow tires
that came off my other vehicle?
thanks in advance
glenn
Old Dec 20, 2007 | 08:48 PM
Eric J's Avatar
Default RE: Sizing of snow tires
Welcome to the forums Glen. Check into the 'New members area' and peruse the rest of the forum.
The wider tires will actually be a detriment to snow handling. More surface to ride up on the snow and hydroplane on slush.The higher profile/larger diameterwill throw your speedometer up a few MPH.
That being said, they are just slightly larger than the others and you'll have enough clearance, the choice is yours.
Old Dec 21, 2007 | 07:11 AM
jks2's Avatar
Eric is right. However, unless you live where snow is a 4 month thing then the all season tires should be fine.
Old Dec 21, 2007 | 11:24 AM
Glenn B's Avatar
Thanks you for your quick response. I will go to the new member's section and introduce myself. To all members and their families have a Merry Christmas and a Happy New Year.
Old Dec 21, 2007 | 11:45 AM
JimKW's Avatar
I would never go with a 225/60 when the car calls for a 205/55. They are going to rub like crazy.
My car calls for 205/50/17 and I run 215/50/17, and have heard that 225/50/17 is too big. When you add the height by going 225/60 instead off 205/55 you are adding height along with width.
gstake
Dec 15, 2014 02:47 PM
thhweb1
Apr 11, 2013 10:41 PM
ignition16
Nov 16, 2011 09:24 AM
metalslug
Nov 7, 2009 01:37 PM
drabina
Sep 7, 2009 08:06 PM
