squeaky and noisy wheel !!
Old Feb 7, 2012 | 05:38 PM
boletole's Avatar
Default squeaky and noisy wheel !!
Hi all
i have a volvo v 70 1998 estate and have noticed a squeaky and noisy wheel noise especially when running at lower speeds. i am suspecting a calliper but i would like someone else opinion before i go down the path of taking the wheel off. could it be wheel bearing or somethings else altogether? any help appreciated!!
thanks in a advance
Old Feb 7, 2012 | 06:16 PM
J. Couture's Avatar
It could be severely worn brake pads. Sometimes they have a clip that squeals to inform you that they are worn. It could also be a wheel bearing.
Old Feb 8, 2012 | 10:23 PM
boletole's Avatar
i have also observed a wobble when i am driving on my steering wheel. is that a calliper,worn out brake or the wheel bearing.
thanks
Old Feb 12, 2012 | 12:46 AM
gdog's Avatar
thanks
None of the above. Do you notice this wobble mostly at slow speeds? If so, it's most likely tread separation on one or more tires; ck it out asap as it could blowout on you; very dangerous.
Could also be something as simple as tires need balancing... have it ckd out.
firstvolvo
Apr 13, 2017 06:03 PM
letsdothis
Jun 5, 2011 08:24 AM
chrisdt
May 12, 2011 10:39 PM
retailguy
May 15, 2008 06:19 PM
S70turbo1999
Dec 20, 2005 11:11 PM
