squeaky steering wheel
Old Dec 19, 2005 | 08:31 PM
S70turbo1999's Avatar
Default squeaky steering wheel
my steering wheel moans or squeaks or something when i turn. is that because its cold or do I need to lube something?
Old Dec 19, 2005 | 08:43 PM
satchmodog's Avatar
Default RE: squeaky steering wheel
http://volvospeed.com/Repair/70steering.php
Could be this. Mine is doing it as well, but it is 3 degrees here now and I have no will to freeze my *** off to fix it.
Old Dec 19, 2005 | 10:23 PM
It could also be a bad SRS contact reel.
Old Dec 19, 2005 | 11:01 PM
satchmodog's Avatar
Is the SRS contact reel any easy repair or is it something the dealer needs to do with their software updates and the usual procedure of software activation.
Old Dec 19, 2005 | 11:38 PM
You can replace it without the Dealer.
Old Dec 19, 2005 | 11:51 PM
satchmodog's Avatar
As soon as it gets a bit warmer i will try cleaning the bearing and greasing it. If that does not work, I move on to the SRS. Right now the single digit temps keep me from caring about a moaning steering wheel.
Old Dec 19, 2005 | 11:54 PM
I hear you been there done that.
Thats why I am in FLA. Now.
Old Dec 20, 2005 | 11:11 PM
S70driver's Avatar
It could also be your Power Steering. When I turn my steering wheel mine moans. I believe it has something to do with the Powersteering, possibly the PS pump or something.
seraphgorny
Dec 7, 2019 03:10 PM
firstvolvo
Apr 13, 2017 06:03 PM
trainlover
Mar 16, 2014 08:48 AM
boletole
Feb 12, 2012 12:46 AM
retailguy
May 15, 2008 06:19 PM
