squeaky suspension
My 1998 V70 has an annoying squeaky sound coming from the front area of the car.
I believe is either thesuspension or the engine dampers but I can't really figure it out.
I can hear the squeakines in particular going very slowly when hitting small bumps. Also when the car is stationaly and I push down on the boy I can hear it so I assume is the suspension.
Does anyone have any idea what is the speific part I need to replace? I hope is not the entire suspension.
Thanks for all your help
Piston
Piston
we do a ton of spring seats on 850's at work. you can check it by taking a 21mm (13/16ths) wrench to the top of the front strut and giving it a tug. it should spring back. if it spins free, it's broken. we charge 1.5 hrs labor for em, and 30 bucks for the part. here's a link to some on ebay, to see what they look like.
http://cgi.ebay.com/ebaymotors/Volvo...spagenameZWDVW
Buphalo,
That worked! I replaced the spring seats and now the squeaky noise is gone. :-)
Now though I am able to hear another noise coming from the front right wheel area... a tlunking noise...
...Could that be a bad wheel bearing? Is there any chance I can replace it myself? any special tool?
Thanks
Thanks
