Stalling when slowing down turning and timing belt question
Old Mar 28, 2017 | 07:49 PM
laurentmg's Avatar
Default Stalling when slowing down turning and timing belt question
My 2004 V70 sometime stalls while turning after slowing down.
Jiffy Lube told me to clean the throttle body. For this they charge $90.
I used to encounter this problem 5 years ago and at that time changing the sparks plugs seemed to have resolved the issue or something done along. I recently changed all my plugs and the igniters as they started to die one by one. The stalling problem hasn't gone away. Any idea what could trigger the stalling and if it is concerning?
My car has 125K miles in it. It's old but runs fine although my power steering fluid leaks and I need to add more every three weeks due to a rack'n pinion problem that's too costly to fix.
Finally do you recommend to replace the timing belt? For my vehicule it's recommended to replace it at 150k miles. That's a couple of years down the road for me.
Thanks!
Old Mar 28, 2017 | 08:17 PM
ES6T's Avatar
The timing belt is due by time and should be replaced.
Old Apr 1, 2017 | 06:00 PM
Any error codes?
sagewhitesage
May 18, 2016 09:33 PM
Mushy41
Feb 4, 2016 06:24 PM
Howard_Woodard
2001-2013 model year V70
Jun 1, 2012 06:32 PM
melissanewton
Oct 24, 2009 09:21 AM
trumpy
Sep 9, 2008 08:18 AM
