stuck rear window
Old Apr 12, 2009 | 08:14 AM
ryst8's Avatar
Default stuck rear window
My rear window got got stuck yesterday. I tried another switch and ruled out that problem. I wasn't really sure where to go from there so I started digging into the door, looking for a way to dislodge the motor from the actual window so I could manually raise the window and keep it in place. I'm really not worried about using the window, I just want it shut. The problem I ran into was that the motor unit is very difficult remove. Can somebody give me advice on how to remove this unit and how to go about raising the window manually?
Thanks.
Old Apr 12, 2009 | 08:28 AM
Did you try powering the motor with a battery to see if it would move?
You need to remove the regulator to get the motor out. Also it needs to work to get it out.
Also to disconnect the glass from the regulator it needs to work as well.
Old Apr 12, 2009 | 09:42 AM
ryst8's Avatar
Default what if
what if none of it works?
Old Apr 12, 2009 | 09:47 AM
Then you need to try to work your hands in there and release the clips on the plastic blocks.
Also with power to the motor try tapping the window motor and see if it starts working.
Obelix
Jun 20, 2022 08:40 AM
andy1971
Jun 7, 2012 11:31 PM
mudiver
West
Jun 25, 2011 07:31 PM
amotin
Dec 12, 2008 09:13 PM
sailordeac
Jun 27, 2008 07:23 AM
