tailgate locked shut, won't open
Old Dec 16, 2007 | 01:18 PM
98T5's Avatar
Default tailgate locked shut, won't open
I was told the latch mechanism is broken.
can somebody tell me where I can find one and how much they cost?
any info is worshipped. thanks in advance.
Old Dec 19, 2007 | 10:59 AM
Paudman's Avatar
Default RE: tailgate locked shut, won't open
Is it?
My own failed twice last week, but it appears to have been something sticking. I removed the rear trim and was able to get my hand down behind it to open the lock from inside the door, to find that it worked perfectly for about a week before failing to open again. Nothing that I can see is broken or worn, yet periodically it fails to open from outside. When this happens, the remote fob doesn't have any effect either so it's not the outside handle, but I think more of a remote electrical problem. I'll try changing the relay. I certainly wouldn't fork out on a new lock mechanism until I've identified that's the problem. Any thoughts?
Old Feb 11, 2008 | 08:06 PM
volwoman's Avatar
You can buy a tail gate lock at FCPGroton.com. I just did for my 99 V70. Mine started off working intermitently, but I did not take care of it in time. When the tail gate was up it would work, but if it was down it would not. I had several wires that had snapped and a bad ground wire. The wires lead through a harness to the tail gate, and if you open and close a lot they will eventually snap. Anyway after I had the wires repaired, the lock jammed and it seems it was one too many jams - at least it was jammed on open! I ended up getting the lock replaced; bought it at FCPgroton for $139 + shipping. (Price depends on lock/chassis number.) I also ended up getting the back door bolted, after one too many repair kits failing to keep the tail panel in place.
Hope this helps.
gkwoods
Jan 23, 2022 10:28 AM
frank weiler
Oct 11, 2012 06:33 AM
98T5
Jan 31, 2011 11:36 AM
morrissey
Sep 23, 2010 06:20 PM
sdcromer
Jul 2, 2008 12:59 PM
