Tech please help...1999 volvo V70 timing marks NON VVT, with coil on plug
Old Dec 28, 2009 | 06:52 PM
panthrogt's Avatar
Unhappy Tech please help...1999 volvo V70 timing marks NON VVT, with coil on plug
hi all....i have been in this forum for about a year but....always just searched previous threads....thanks for all info on archives...
current problem....
i have a 1999 volvo v70 (base model) B5254s 20 valve...(production date 03-99)
the car DOES NOT HAVE Variable Valve timing, the car DOES have COil on plug... i am unsure of the timing marks ...do i follow the same steps as the 1998 v70 (and 850's) with marks at 11 oclock and 2 oclock ...or do i follow the marks on the newer engines that line up at the 12 oclock marks....logic tell me to do the old method but the timing cover has marks on the 12 oclock marks...really really confused ...
thanks in advance
Old Dec 28, 2009 | 08:45 PM
You go according to the timing marks on the belt cover. If they are at 12:00 then set them to that position. Also make sure the crank mark lines up.
If it needs to be set like the older cars then the crank will not line up.
Old Dec 29, 2009 | 09:58 AM
panthrogt's Avatar
thanks for your reply....the timing belt snapped so i have no starting point....i plan to re-due the head but i do no want the mess up all my hard works and $$ in valves....the timing marks on the cover are on the 12 oclock mark, HOwever i bought the car used and i am afraid maybe that part is no original...i should have taken a look at the timing marks before it snapped ...but thats life....again thanks for your input
anyone with a similar engine know the marks ?
thanks
Old Dec 29, 2009 | 08:09 PM
https://volvoforums.com/forum/volvo-xc70-17/how-repair-timing-belt-head-gasket-bent-valves-18322/
Take a look at that post and maybe make your own cam lock tool and install it and see where the timing marks line up when you are done.
If you put it all back together and set them at 12 and it is wrong as long as you are tuning the motor over by hand easily it will not bend the new valves.
Edsautohouse
Dec 15, 2013 02:36 AM
Hopper
1998-2000 model year V70
Sep 15, 2012 10:48 PM
kmellott
Dec 12, 2008 08:10 PM
