Terminal Oil Leak
I had also considered a blocked feed pipe but if it was blocked then the turbo would have let go and there would be no oil to leak from the return gasket... or has the banjo at the top of the turbo on the feed pipe let go and this is just peeing everywhere.
replies on a postage stamp to..... hey my post count has gone through the roof! If you need more than a one line reply then e-mail me gavin (AT) i-buildings (dot) co (dot) uk I'll post it when the forum is fixed.
Just a quicky had same problem with my t5 Oil trap blocked over presured the crank case main sill , all the oil on therear screen is cause by the airodynamics of the rear of the car the oil will blow back from the front of the engine towards the back and yes it will cover all
Not a simple job to do but can be done at home
Regards Mike
Regards Mike
Tech,
You are a genius!checked all the banjo fittings, the oil feed banjo in the block turned about x3 clicks onratchet spanner everything else was fine (x1 click). Fired it up and got over a gallon out in 3 seconds... guess the pipe was fractured and tighteningthe banjoopened it up, anyway new part ordered (£30) will be here tomorrow. I am counting my blessings that I spotted the leak before the pipe burst!
Cheers mate... owe you a pint for that
That "little" crack dumped over a gallon of oil in 3 seconds! Of course it wasn't as big as that untilI tightened the banjo
I think it's fairly obvious that it started life as a stress fracture [:@].
rippertele37
May 19, 2010 04:46 PM
