ticking relay
Old Dec 3, 2007 | 08:43 PM
plaganir's Avatar
Default ticking relay
Group,
I have found my V70 with the battery dead on a couple of occasions. After a short investigation, here's what's happening.
After I turned the engine off and lock the doors, 30 seconds later, a relay "click" once behind the dash near the steering wheel and then, a relay ( or something that sounds like one) "click" in each front door. The clicking goes on like a bomb until the battery dies!
I replaced the battery ( the dealer suggested to!) and it didn't fix anything.
Any hint?
thanks in advance.
Old Dec 5, 2007 | 05:46 PM
Default RE: ticking relay
You might have a bad relay under the dash or a bad door module.
Old Dec 5, 2007 | 08:11 PM
plaganir's Avatar
Well,
I tried removing the front door module fuses and the electric windows fuse but the rely still click!
Thanks for your help!
Old Dec 5, 2007 | 08:20 PM
Close the latch to let the car think the door is closed and try to trace down the relay that is clicking.
Old Dec 5, 2007 | 08:37 PM
plaganir's Avatar
The relay under the dash clicks only once while both front doors start clicking endlessly like a bomb!
Thank you for you replies
Old Dec 5, 2007 | 10:07 PM
If you can find the exact relay swap it with another one and see if it still does it.
Old Dec 9, 2007 | 09:07 PM
plaganir's Avatar
I replaced the car battery and it seems like its fixed now!?
This problem might come and go!
Old Mar 8, 2008 | 07:52 PM
plaganir's Avatar
The problem is still there and it's ticking me off!
This is what I found so far:
if I pull either the left or right door module fuse (no 34 and 35), the ticking continues in both doors. If I pull the door modules fuse (no 27), the ticking stops.
As for now, my best solution is to pull fuse no 27. I'm shopping for an OBD2 unit to get the codes and fix this once for all!
Patrick
Old Mar 10, 2008 | 05:45 PM
I still think it is a bad door module.
Captain Zov
Jun 18, 2021 12:01 PM
sleech
Jan 25, 2020 05:07 PM
redbottle
Dec 29, 2009 11:25 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
Wounded Horse
Jan 15, 2007 08:46 PM
