Ticking Relay
Old Jan 13, 2007 | 01:21 PM
Wounded Horse's Avatar
Default Ticking Relay
In the space behind the LH rear lamp cluster on my 97 T5 estate, there is a cicuit board - long and narrow - that has the legend RYDER on it. It ticks every 2 seconds when the engine is running. Is this the fuel pump relay? It's a bit irritating.
Old Jan 13, 2007 | 01:36 PM
Default RE: Ticking Relay
Would you be able to post a pic of it?
Old Jan 13, 2007 | 06:21 PM
How do I post a pic? Do I have to host the pic somewhere and link to it with [img] link /[img]
The device is about 4 inches long and 3/4 inches wide with three wires at one end and two at the other with I think 2 small relays on a mica circuit board containing resistors and the like. It has an unclippablee black plastic cover. To get at it I removed the carpet rectangle in front of the light cluster and parted some cables and eased it out on its own cables. Says Ryder on the plastic cover. I should also say that it doesn't always make the noise but when it does it's annoying. Thanks.
Old Jan 13, 2007 | 07:54 PM
If you click post reply and not use the fast reply you shold be able to upload it from your PC.
If not then you can host it and use the img links.
Old Jan 14, 2007 | 11:06 AM
Pis as requested. Thanks
[IMG]local://upfiles/8340/893169C9842043B98A3F2104A9A27130.jpg[/IMG]
[IMG]local://upfiles/8340/ACC8DBAEF3A24E87BCC42448718A66B8.jpg[/IMG]
Old Jan 15, 2007 | 08:46 PM
That looks kind of like it is a adapter for a trailer hitch wiring.
It is not factory.
Captain Zov
Jun 18, 2021 12:01 PM
sleech
Jan 25, 2020 05:07 PM
redbottle
Dec 29, 2009 11:25 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
plaganir
Mar 10, 2008 05:45 PM
