Timing belt help
Timing belt help
I am new to this site. I have read all the past timing belt questions however I bought my car without a timing belt on it with bent valves. replaced the valves and I have 3 possible marks on the crank pulley that could be the mark. I have not seen a repair manual that points out which of the 3 marks on the crank sprocket is the correct one.
Can someone help me. The engine has the variable valve timing FYI.
I have put the belt on to the one I thought it was. at idle it was great. started to drive and it started backfiring. I pulled the belt off and moved it to the 2nd mark drove it. seemed ok however the engine light came on. I do not have a scanner and Have no way of checking it right now. I may go buy one tomorrow.
Thanks for the help.
Keith
Keith
runs got new problem
Thanks for your help. I must have been paranoid. I reset timing today and it runs fine. I drove it and heard what I thought was a backfire like before. I thought no way! I drove a bit further and then I realized that it was the right front strut bearing was bad and the strut top was making a "pock" noise that sounded just like the engine was backfiring.
Oh well runs great now. Thanks.
Now I reset the ECU and the first time I start the car the engine light does not come on. The second time I start it the engine light comes on with a p1655 CVVT code. Do you have any suggestions on where to start?
Thanks again
Keith
Thanks again
Keith
