Tire Bolt Thread
Old Jul 31, 2008 | 08:39 PM
McBain's Avatar
Default Tire Bolt Thread
I did a search any couldn't find anything on the tire bolt thread. I have two holes on my rear tires which have buggered threads. I wanted to chase them out but I don't know what tap I need to purchase. I have done some seaarches on this forum as well as the internet and found a few hits that indicated the thread was a 12mm X 1.5 or 1.75. Well I managed to get a thread guage and found that it appears to be a 1.5 so I purchased a 12mm X 1.5. Unfortunately the tap goes right through the hole which means it has to be biggr then a 12mm. Would anyone happen to know what size tap is required? TIA
2002 V70
Old Jul 31, 2008 | 09:47 PM
Default RE: Tire Bolt Thread
I think it might be a 14MM but not 100% sure.
Old Aug 1, 2008 | 01:39 AM
mr maraki's Avatar
14 x 1.5 should get you there (2000 model and up).
Previous years were 12 x 1.75.
Old Aug 3, 2008 | 01:19 PM
Rsterns's Avatar
I have a 98 V70 T5, and just last week had one of my aftermarket studs shear. It is a 12 x 1.5 thread, I can guarentee it. Could someone have possibly drilled and tapped the hole for a helicoil? If they did, that thread would be a 14mm. but not standard thread. If you can find someone with a 14mm helicoil tap, that would confirm if is threads right in or not. That's about all the help I can provide.
Good Luck,
Old Aug 4, 2008 | 06:24 PM
The 1998 is the 12X1.5 the P2 cars 1999 S80 and 2001 S60 and V70 are bigger lugs.
Old Aug 16, 2008 | 11:38 AM
McBain's Avatar
Thanks for the help. I finally located a 14M X 1.5 tap and chased out the threads. The new bolts now go in with no problem.
HiRez
Mar 23, 2015 07:50 AM
tdrendel
Feb 11, 2013 08:54 AM
Counselor828
Aug 22, 2011 12:19 PM
hibrad2005
May 21, 2009 09:05 AM
daisydaisy
Jan 26, 2006 11:52 PM
