Rear Brake Light Puzzle
Old Nov 12, 2007 | 04:26 PM
alpamayo's Avatar
Default Rear Brake Light Puzzle
Greetings.
I have a 2002 V70 T5 and about 8 months ago I started getting a warning on the dash and a message -> "check stop light". I seem to recall one light not working. Of course time went by and I did nothing about it. Well, yesterday I noticed neither brake light was working except for the long bar atop the rear window. I thought I was dealing with burned out light bulbs and so I got two new ones from the dealer. I replaced the bulbs but still nothing works. I thought then perhaps I was dealing with a burned out fuse. I looked in the back fuse panel (located in cargo area wall) but the fuse is just fine. So given 1 of the 3 brake light works (only the baratop the rear window), where should I looknext? Is there another fuse I should consider, I checked all in the back and all in the engine compartment (front) and thus far have not found a burned fuse. Is there a relay parhaps I should consider ?? Please HELP !
Cheers
Old Nov 12, 2007 | 06:04 PM
Default RE: Rear Brake Light Puzzle
Check the relays in the rear fuse panel I have seen them go bad a couple of times.
The 3rd one isn't included with the rest of them.
Old Aug 16, 2008 | 08:28 AM
emf's Avatar
emf
tech-
Just had the same problem with my brake lights, 2003 V70 2.5T AWD. Do you know which relay controls the brake lights? I wiggled and reset them all, but to no avail.
Thanks,
emf
Old Aug 16, 2008 | 08:59 AM
Im working on finding info to post with diagrams.
Old Aug 16, 2008 | 09:36 AM
I have to do some more work cannot seem to get disk to open info. Also try searching I know I have posted the diagram before as well.
Old Aug 16, 2008 | 02:59 PM
rules's Avatar
The right hand tail light on my car gets really damp (looks like the beginnings of a swamp at this stage) ... anyway, what I'm trying to say is, could it be possible for the "contacts" for the light bulbs to be corroded/dirty and therefore not working?
Old Aug 16, 2008 | 08:00 PM
Yes that could be possible for yours.
admasters
Dec 10, 2013 09:24 AM
insulanus
May 8, 2010 12:20 AM
squirtymustard
Apr 19, 2010 10:59 PM
MJAlex
Sep 24, 2007 06:25 PM
Desperado
Apr 10, 2005 02:36 PM
