Tires Question On 2001 V70 2.4t
Hello,
I am trying to replace tires on my 2001 V70 2.4T which currently running 205/55 R16
I want to go to 215/55 R16, but I can't seem to find anything online regarding width of stock 16" wheel and if it will be fine on the stock 16" rims that come with V70 2.4T
Is it safe to put a bit wider tire on these stock 16" rims?
Thanks a lot.
Thanks a lot.
on
You will probably be OK. That is not much larger. You would only run into a problem if your wheels were narrow (6.5" or less) If they are 7" - 7.5" then the little bit wider tire should not hurt. You might get some slight rubbing on full lock turns, but I doubt it.
You can't find anything?
DISCOUNT TIRE DIRECT
205/55 R16
TIRE RACK
205/55 R16
Hope this helps, was able to find them both in less then 5 minutes.
205/55 R16
TIRE RACK
205/55 R16
ORIGINAL: v70 2.4t
I run 215 55 16, a little rubbing on full lock but nothing major.
good luck
v70 2.4t
good luck
v70 2.4t
I guess it seems you said it works good and you do not have issues.
Thanks
ORIGINAL: woodkayakr
Stock 16" wheels on your V70 are 6 1/2" wide; information found when I was looking for winter wheels.
Another member above mentioned that it is working pretty good on his car.
gstake
12-15-2014 02:47 PM
Subvol
12-11-2011 06:56 PM
