tranny drain plug
Old Aug 25, 2006 | 07:34 AM
v70 2.4t's Avatar
Default tranny drain plug
Hi, i am going to drain my tranny and refill with mobil 3309 ATF , where is the drain plug located ?
also i guess you fill it up through the dipstick, any ideas on what works well would be appreciated.
v70 2.4t 2000 2G
Old Aug 25, 2006 | 08:38 PM
Default RE: tranny drain plug
Once you climb under the car you really can't miss it.
It points towards the engine.
The wrench you will need is a 15/16 or equivelent in Metric.
Old Aug 28, 2006 | 12:21 AM
v70 2.4t's Avatar
How much fluid will come out when i drop it.
V70 2.4t
Old Aug 28, 2006 | 08:50 PM
Usually about 3 to 4 quarts. It will Vary some.
Old Aug 30, 2006 | 07:32 AM
v70 2.4t's Avatar
I am almost scared to post this (after all the problems with tranny fluids that are suitable for volvo's of late but any way here goes).
I can not find mobil JWS 3309. or in Australia its called ATF 3309, unless i get it from volvo, after i take out a 2nd mortgage to buy the stuff...
I called mobil Australia, they told me that Toyota T4 fluid is the same...
I called the Toyota dealer they have it $26.95 for a four litre bottle...
can i use this stuff.....is it safe..
v70 2.4t
jbarnes
Jun 12, 2013 11:46 AM
jorhyne
Aug 20, 2008 10:54 PM
tobo57
Jan 12, 2008 06:37 PM
wheelsup
Nov 7, 2007 02:26 PM
roughyear
Feb 10, 2005 10:02 AM
