transmission cooler fittings - release and repair
I have a small leak, apparently between the poly tank and the radiator header on the trans cooler (passenger) side. The fittings for the cooler line look like a challenger to remove from the radiator without damaging the plastic connections (northeast road salt) . What are the tricks? Is there a special tool required?
Have thought of temporarily using some stop leak, but think that may reduce cooling efficiency. Opinions?
Thanks for any help.
uniquemicro
09-02-2009 10:19 PM
