transmission slipping
Old Feb 12, 2007 | 07:02 PM
uncle's Avatar
Default transmission slipping
Had the codes pulled for my transmission."Lock-up fucntion slipping or not engaged" Is this going to be just wear and tear only resolved by a new tranny? Symptoms are the standard crappy tranny problems, slipping, delays into gears and shift flares.
Old Feb 12, 2007 | 09:44 PM
Default RE: transmission slipping
Might have been a glitch.
Old Feb 12, 2007 | 09:52 PM
uncle's Avatar
in the DTC or the transmission?
Old Feb 13, 2007 | 12:16 AM
In the transmission.
A soleniod might have gotten stuck.
Does it shift better since it was reset?
Old Feb 14, 2007 | 11:27 AM
uncle's Avatar
Not really. It still plays up when it gets hot. Sometimes when it starts to get bad it shifts a little better manually, but not much.
Old Feb 17, 2007 | 01:28 AM
Sounds like there is a problem inside.
I would drive it till it dies.
Old Oct 22, 2007 | 11:52 PM
cali to vegas's Avatar
Did you ever get this problem sufficiently solved? I also have 2001 V70 T5 wagon that hitches and clunks when I decelerate. The dealer can't seem to figure it out. I have an extended warranty that is about to run out. They won't pay if the dealer can't prove a failure. Really getting nervous about this. Your feedback is appreciated.
Old Oct 23, 2007 | 05:28 AM
v70 2.4t's Avatar
Hi, I think uncle is os at the moment....so i dont think he solved his problem.
You need to get your tranny to throw a code .
I would kill the thing and hope it throws a code and then take it to the dealer..
I know it sounds harsh...but this i think would be the only way.
get them to print the code and associated problems out and stick it
to them.
I have the same issue...only when the car gets really hot..
i change my fluid out every 20k km and i will drive it till it drops out.
good luck
v70 2.4t
jeffrisley
Jun 14, 2015 01:48 PM
crashin
May 30, 2007 08:26 PM
Athilla
May 15, 2007 03:04 PM
rbwhitt
Feb 27, 2006 01:25 PM
youngishstew
Dec 24, 2005 10:28 PM
