tuneup time?
Old Oct 23, 2008 | 06:46 PM
rtm's Avatar
rtm
Default tuneup time?
check engine light came on today
flashes when car downshifts/under load
OBD II gave me these codes;
PO300 RANDOM MISFIRE
PO301
PO302
CYL1&CYL2 MISFIRE
should I just tune up car and then worry about codes?
Old Oct 23, 2008 | 06:48 PM
TIPSP's Avatar
Got Boost?
Default RE: tuneup time?
When was the last tune up?
Old Oct 23, 2008 | 06:58 PM
rtm's Avatar
rtm
have only had car about a week
previous owner was less than honest about condition@sale
although there is an oil change sticker on inside of windshield from a service station in his area
not due for oil change for about 1000 miles
may call service station tomorrow to verify service intervals
wife has 1999 v70, but mine's a little different (cap&rotor vs. coilpacks)
guessing that's where to start?
Old Oct 23, 2008 | 07:03 PM
TIPSP's Avatar
Got Boost?
Also do spark plugs. If the coil wires are original, you can see white or yellow letters (according to tech) and they will have a date on them.
Check the Air filter too.
Old Oct 23, 2008 | 07:05 PM
rtm's Avatar
rtm
thanx 4 that
do you mean plug wires?
Old Oct 23, 2008 | 07:07 PM
TIPSP's Avatar
Got Boost?
Yes...sorry I doing something else while typing.
Old Oct 26, 2008 | 04:36 PM
rtm's Avatar
rtm
tuneup complete,
warmed up car and took test drive
no codes detected
took car out again later
same code at higher rpm TRANS IN POWER MODE
p0301 misfire cyl 1
cat. converter issues?[/align]
Old Oct 27, 2008 | 07:38 AM
If you have put all new parts on and still get it I would look at the injector next.
Old Oct 27, 2008 | 05:15 PM
rtm's Avatar
rtm
last post should say trans in sport mode
either way, problem only exists @ high RPM
trying AMSOIL injector cleaner
have been running 93 octane fuel
platinum plugs installed
plug wires were not cheap but are not a brand i recognize
dmur
Mar 5, 2015 03:14 PM
silverstreak98
Mar 8, 2011 09:28 AM
silverstreak98
Mar 3, 2011 03:49 PM
n3cr0
Nov 14, 2010 09:14 AM
Frejborg
Feb 4, 2009 01:39 PM
